pontiac forums   pontiac forums
Pontiac classified ads belong ONLY in the Classified section. Not in model-specific forums!
andys auto sport
Go Back   Pontiac Forums > Past Pontiac Vehicle Discussion > Pontiac Fiero Forum
Register Pontiac Store FAQ Members List Calendar Mark Forums Read
Pontiac Fiero Forum Discuss topics regarding the Pontiac Fiero.
Reply
Thread Tools
  #1
Old November 8th, 2009, 02:26 PM
Here4u2hate Here4u2hate is offline
Junior Member
Here4u2hate is on a distinguished road
Question 85 Fiero DING
I have an 85 Fiero SE with a 2.5L engine.... When I am driving the car will randomly ding, as if it is announcing an alert or warning. Any ideas on what it could be
  #2
Old November 8th, 2009, 04:41 PM
Oreif's Avatar
Oreif Oreif is offline
Senior Member
Oreif is on a distinguished road
You have either a hood, decklid, or door switch that is loose, The E-brake handle is loose or the switch is mis-aligned.
  #3
Old November 9th, 2009, 01:00 AM
Junior Member
All those are closed, the ebrake is un hooked.. no lights come on or anything
  #4
Old November 9th, 2009, 07:45 AM
Oreif's Avatar
Senior Member
Even though all are closed, the switches themselves could be bad or corroded.
If the E-brake is unhooked, There is no tension on the lever and it will bounce on bumps in the road and ding. Try disconnecting the connector on the E-brake switch and see if it goes away. If all else fails, Pull the blue box that is under the passenger side dash. This is commonly called "The blue dingy thingy" It is the dinging module.
Reply
Tags: , , , , ,
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.10
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
pontiacowners.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacowners.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2010 pontiacowners.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
custom floor mats | pontiac performance mufflers | pontiac performance exhaust systems | racing seats | pontiac euro tail lights | pontiac air intakes | pontiac projector headlights | pontiac ground effects | pontiac body kits, hoods and lambo doors | pontiac body kits | pontiac carbon fiber hoods | air suspension kits | air suspension parts
