Evilcowboy420
- May 20, 2013
Hi,
I am new here so hi.
I purchased a 88 pontiac sunbird. After purchase I ran it a month and some things started popping up that seemed to tell me it had some problems. I had expected in a 25 year old car it would need some stuff and was willing to do the work because the under carriage and body was pretty nice.
What it needs:
Head Gasket
Valve Seals
Alternator (don't wanna wait for it to die. Replacing because got a nice squeak from the bearings)
CV Shaft
What I've replaced:
Timing Belt
Drive Belt
EGR gasket(cleaned while removed)
Valve cover gasket (new plastic core one)
steering linkage
cleaned (IAC valve, Air housing, valve cover, and a few other things)
Rad caps
thermostat
Now my questions.
I've got the head off and am rebuilding it. There is a slight warp around cylinder 4 where the gasket blew. I can fit a .0015 feeler gauge under the area barely but cannot fit the .002 under it. Is this still in tolerance for this head? The car did not overheat at any point but it was pretty apparent where the gasket blew right in front of cylinder 4. As I have researched this was pretty common for this engine or is mine just special?
Do the valves on the head need to be lapped or should they seal fine as is?
When fitting the camshaft carrier back to the head should I use a high temp silicone or just use the same tacky brown stuff GM used originally?
I also found it odd that the rocker arms didn't bolt down but rather sat in there.
With the head removed I cleaned it up as oil and antifreeze was all over the head.
Here are a few pics of the head after it was pulled and the gasket failure. I will be posting more pics as I take them.
What it needs:
Head Gasket
Valve Seals
CV Shaft
What I've replaced:
Timing Belt
Drive Belt
steering linkage
Rad caps
thermostat
Now my questions.
